2005 dog chopper
TeddyRay
I am needing a detailed wiring diagram/schematic for my 2005 dog chopper, also a little helpful information.
Yesterday I was out riding the old chop and she was running great, pulled up at gas pump shut bike off paid for gas took a smoke break so I’m going to say sit there a total of twenty minutes get ready to continue my ride and turned the key on and there it was staring me directly in the face absolutely no power to anything.
The chop has the original EHC never has given me any problems has 87,542 miles what to start with first thing I checked mega fuse the checked ignition switch was working correctly no lights at all on the EHC and nothing on bike has power
dentdude36
Banned
Load test your battery make sure it’s good
Jersey Big Mike
100K mile club
Check the battery voltage?
Jump from another battery (car -- NOT RUNNING)
Check your stator and VR output. Sounds like you rode and the battery wasn't charging.
TeddyRay
Sorry for the delayed response here ended up having to go to work and just got home a few minutes ago!
I put a new battery on it because the original battery that was on it when the problem accrued would only hold about 11.7v, still had the no tech lights or anything so I check continuity on every wire switch everything checked out good all the way up until I found a bubbled up spot in the ignition module the got to looking at the ehc and found a bubled spot also like it had been hot and sure enough had them tested and they are both junk! So complete new wiring harness ehc and ignition module on the way! Thanks for the help .
TapioK
Something caused those both to burn, check charging voltage before burning new parts too...
TeddyRay
This is what it’s going to look like minus the seat it will be black and I will have the windshield tinted limo black!
