Thanks Doug. I knew the values were low. I was going with 10 ft bs.
I opened it up again and this time pulled the pressure plate and clutch pack out. Here is the problem:
The splines on the friction plates have worn grooves all the way around the drum. I’m looking at it and now see how the friction plates would get stuck on the grooves and not be able to slide back and forth with the clutch lever. You pull on the cutch lever and the plates say ‘I don’t think so—I’m in a groove here.’
Dunno what the drum and new clutch pack is gonna cost me, but I’m not happy.
Going now to get the impact wrench and set to left hand threads to get the basket off to prepare for replacement.
