need a some help
njbiker20088
I have a aih but it has an s&s 111 this bike has never let me down. I parked it for about 4 weeks well sunday I start the bike and it fire right up but it stared to spit oil out of the breather. I shut it down cleaned it up and started it again and nothing no oil let it run so it went for a ride ran good as it always did . What could have made this happen? any help would be great T/K you I know its not a dog but you guys know lot.
41bigdawg
Let the Big Dawg eat !
Sounds to me like you had some drainback into the crankcase while it was sitting for 4 weeks. Once you started it up and it ran for a bit the oil pump scavenged that out and it was fine. Just my thoughts, im sure one of our experts will chime in with some knowledge.
njbiker20088
howit do fix
There is no said fix. Look at it like this. My bike is a dry sump style oiling system. Wet sump is like a car or the asian type bike engines. Dry-s needs to keep oil off the crankshaft weight throws. NASCAR cars use dry-s so the crank does not drag in the oil. All that effort to make more HP so in a way this engine design had a racing trick going on-wink-wink!
The next part is the oil in the sump tank. How much pressure is on top of the oil in the tank? 14.7 psi. So in a way, there is 1 atmosphere on the oil pump blades. Spread your fingers out and engage the other fingers so they interlock. See the air gap between your middle finger in between the 2 fingers on the other hand? That's how the oil pump works as it captures that little wedge of oil, basically. Those 2 gears spin so fast, it produces pressure within seconds.
The part you can't fix is the oil. Back in the 1950's the army knew oil could be thinned out to a millionth of an inch. So imagine how those pump blades are not made to tolerances to hold back oil. With that said, can you see the 1ATMO snake thru the blades as they have that much pressure happening every second and you let the bike sit? It's just something inherent about the oil winding up in the dry-s cavity and the return is being pulled back into the tank eventually, but the windmill effect inside the crankcase with that much oil, has an escape route just for this.
The crankcase has to have 14.7 psi too, so the breather hose has that dry-s to let the compression bleed off as the air does go past the rings some and there is your excess air. So that buildup too is addressed by the breathing system. I usually lift up my trousers, slap my hands a couple of times and say, well, that takes care of that!
Check ball is a band-aid fix. Main problem are the blades. So all that disassembly to remove the compound and it repeats after a few thou or hundred miles of pounding once again. I'll pass on that repair for many reasons.
SEAL-rider
Thanks Sven. I did the check ball repair and it slowed the seepage but did not completelystop it. I still end up with 2 cups in my crankcase, but it does not spew out of my breather.
41bigdawg
See, I was right :) One of our experts chimed in with a perfect explanation...Thanks Sven :chopper:
PacoPetty
I was going to say the exact same thing...
njbiker20088
should i change the oil pump over the winter ?
