Jeffrey Leatherwood
Ok, so I tested the hand controls with a meter. Using the connector under tank:
Black is common (ground I assume)
Continuity with red when you push Run
Continuity with blue when you push off
Continuity with green when you push start
Continuity with brown when you push turn r
I’m not sure what the orange wire is for??
Any ideas?? I assume if the button press makes continuity with the common (black) that the button is working properly? I also tested all circuits for short against each other without any bottoms pushed (none found)
And then just to be through I checked continuity against all circuits with true ground (the frame) and found none.
It appears as though my hand controls are working properly
DOCs or RIP will get you new backbone wiring if you decide to condemn what you have now.
