roadie1389
I did a search and the posts are so old that no pics are showing. I am thinking of converting the ignition in my 04 Chopper to an Ultima or like Single Fire. I want the retain as much original wiring in-case this ever needed to be converted back. Anybody have any pics of how you ran the wiring. Based on my initial "thoughts" the coil has 1 +12V wire an a trigger in the coil area, so I already have to run a new wire (might as well run all 3. There is a 12V wire under the seat and also the tach wire under the seat. So do I run a new harness with 3 wires to the coil or did you guys run from the nose cone up the engine to the coil and bypass all the wiring under the seat and up the backbone?
