Daymaker
Milco
The Flying Dutchman
Yes Sir...i have that one in both bikes. One has about 6k miles the other gas 2k both no issues.
Thank you!, and does this also solve the problem with the burned headlight connector?
The OEM plastic connector shouldn't melt as the current is much lower BUT I would still replace it when you got it apart anyways just incase. No reason not to put a ceramic one in the headlight regardless. Who knows once you get it apart it could have been replaced anyways already.
Milco
The Flying Dutchman
OK thanks again! I will look where I can purchase the ceramic one!
It's got the same exact light output/Lumens (4000) so it's got the same brightness as the sunpie. It actually doesn't list it's lowbeam on the website.
http://www.lamonstergarage.com/lamo...light-for-f3-st-parts-accessories-motorcycle/
The light pattern on the daymaker probably makes it seem less but it's the same.
Lamonster LED is
1/2
the wattage, no need for ceramic connector
Element specifications (per element):6063 Aircraft aluminum construction.
6000k color rendering.
4000 lumen.
360 degree light beam angle.
24 watt per bulb.
2.0amp (+/- .2) power draw. Stock halogen is 4.58amp.
H4 connector for full plug and play operation.
Daymaker,
Mirror Lighting Type Headlight
Voltage 12 volts
Wattage 45.00
SB03chopper
Go mine today, installed, looks great. Got the 2018 $42 one, chrome, and plug an play setup. Like the pattern instead of a full beam, lays with the land, gives more shoulder lighting.
Went out today and now I don't have hi or low beam lights. Waiting for the ceramic connector to come b4 I open it up & install the Daymaker. Hopefully its not a bigger issue. To be continued.....
