Speedometer
shansel88
My factory one always worked fine, I just chose to take it off and go dakota digital - Never had any issues with it though - 15,000 miles
I believe DrRx was looking for a black face original speedo. If your wanting to get rid of it, give him a PM
DrRx
2007 Bulldog/2009 K-9
Are you looking to get rid of your original? I can always use a spare and just took a blue Dakota off of mine. It has 11-12k mi on it
shansel88
I'll hold onto mine for a little while - only because I just seem to hoard parts that I replace in case aftermarket ones fail - not because I have any intention of putting it back on - or even selling the bike.
Mike manson
When u order a speedometer do you need anything else but mounting bracket
Mike manson
Mine works just looks dumb my bike is wired for halrley now and they put risers and drag bars on so my sits out in open just weird looking
Mike manson
I asked the people selling this is there anything else I need to install besides mounting bracket nobody can give a answer
Are you talking about the Dakota digital that you posted a picture of?
You should only need the bracket, you will have to splice the wires and solder into the current speedo wiring unless you used a connector to plug the wires together. Pretty easy to do
Mike manson
i want under the bar this is what I got now my bike has been wired to harley so not sure what’s in mine now
More than likely it’s a solid wiring harness which means no connectors. It should be easy to cut the old speedo out, solder them to the new speedo and use heat shrink over the the connection.
