bulldog air ride
bdwolf
has anyone experienced cornering problems with the air ride on a bulldog.all the way up i have to really be careful taking turns.not even agressive turns i will scrape.is there a way to adjust ride height.with it all the way its still too low.
PAUL NOBBS
I brought one into UK - casings were scraped so I took out air ride and put 422 progressive shocks in - loads of clearance now and can take UK roundabouts with ease1
05chop
My experience with this if I forget to air it up and first turn I make it won’t turn. Air ride should raise up from just touching fender to apox 2inch and hold and not on the bump stops. Take a look under at shocks make sure there not leaking. Could be movement in swing arm too.
05chop
If your air shocks are going up and holds air (measure dropped to ride height) it could also be other non air shock. Did you have chance to look?
pknowles
RETIRED
I weigh 190 and keep the AR @ 125, I do still scrape but I also scrape with the K9 without AR.
Dam pat I weigh about the same and try to keep mine around 75 pounds. Mine is on the K9 and don't have a problem scraping the pipes but I don't go very fast either.
Brandon Downey
Yeah adjusting from turning on a sport bike to a dog took 2 scrapes to slow my ass down lol. Scared the shit out of me the first time but I have it figured out now. You all already know you can't lean these babies over like a typical bike.
kickstart
Paul,
Maybe the K9 might sit a little higher. I rub more on the Bulldog than the K9 then again when I put Kuryakyn pegs on the K9 the first ride I leaned enough to brake off one of the acorn nuts and I really don't ride that hard anymore.
