Quick Question
MossBerg590
Throwing a little breather filter on the breather line from the rear head that usually goes to the air cleaner. Does it matter if it is facing up? Trying to fit it in where it won't rattle and looks nice and if Its facing up it looks pretty good.
john sachs
What should be done with the smaller hose from the front cylinder John?
Leave it as is unless the engine is pissing oil.
If it is pissing oil, I block the front head vacuum line off. Block the 2 hose barbs on the intake manifold, and vent the back of the engine case next to the oil pump. They're 2 plugs there. 1 straight, 1 at an angle. Your choice, install a hose barb and a piece of hose, with another black & white valve in it, and vent that to the ground also.
John
Thanks
Paul.
pauly
Only just got your reply today John as I have been away working.
Thank you much appreciated.
Paul.
