I spoke to him on friday, He's Back up and running.Is he back open for business now?
Good to hear Curtus is up again.Curtis, aka KaptinAmerika
Long Time Multiple Big Dog Owner, Long Time BDB Forum Member, Long Time Big Dog Parts Supplier, Long Time Custom Big Dog Parts Manufacturer, Long Time all around Awesome Dude
Wild Steed Worx & Services http://www.wildsteedworx.com
What an introduction!!!! He´s been here once and never came back...Hi. I am trying to track down turn signal plugs both the three wire out on the signals and the six wire under the tank does anyone have information where I can find these?
Personally I wouldn’t use those computer connectors on a motorcycle due to the elements. You can get jst waterproof connectors through wild steed worx and other places. If you are looking to change the connectors I would look at Deutsch connectors.Thanks. Another member suggested a source for them online I have to get the name at my office . He said they are the connector plugs for computer cooling fans . I've been searching to find the name of the company again . I blacked out my front and so I have it all apart
They can be done without the chrimping tool. I am sure it would be easier but I found and electrical chrimping tool at harbor freight for cheap and it works goodGet the right plugs, cpu fan plugs are not waterproof. Get them from Curtis at Wild Steed Worx, I got a bunch when I rewired a new rear setup for my bike. You'll also need the pins and crimping tool if your replacing everything.
Do you think they'd have a three wire with braided shield and and a clear coating?You can get these made up to correct length from Dead One customs. He made all 4 turn signal ends for my 2009 Coyote and I soldiered them in. His ends come like Big dogs original (same wire size and colors) so you can to use the tool and put it back like stock I soldier mine in even though I have the tool. Somebody cut mine all out and put turn type wire ends in what a mess. Dead one wiring comes with correct wire colors for both side front and back just like stock just tell him the length you need, easy to figure out what wire goes where. I also used his LED turn signals on the same bike better end with wire pig tail on LED light that does not break off like stock ones do. Brighter pin than the stock ones also. I also left extra wire on end so I could pull them out to change if I need to.
Post some pics of the paint when you get a momentThanks for all the good info I plan to buy a handful of them. I got my blacked out front end parts from the painter today they look pretty bad ass
This one was recomended by Curtis when I was chatting with him. Alot cheaper than the stock tool. Worked great but like you said, I'm sure there's other options.They can be done without the chrimping tool. I am sure it would be easier but I found and electrical chrimping tool at harbor freight for cheap and it works good
That is close to what I use but I only paid about 10 bucks for the tool.This one was recomended by Curtis when I was chatting with him. Alot cheaper than the stock tool. Worked great but like you said, I'm sure there's other options.
