Yepper, give him a call, he was as of the last time I talked to himI didnt now Dead Ones was rebuilding starters..
Possibly...the DSSC never took off. Maybe the starter is too low in the splash area.Would it be safe to assume Harley figured the problem with Dropped Starter quite few years or decades ago....?
That is what I meantPossibly...the DSSC never took off. Maybe the starter is too low in the splash area.
Removing starter on 2005 Chopper. I think a recent noise I have been experiencing is the pinion shaft not receding properly due to grime. I want to remove it and do a full cleaning and replace what is necessary. I will also confirm that oil relief groove is cut in the half moon spot. My question is how much do I need to remove to get the starter out. Does the final drive gear housing need to come off? - Pipes? Since it is an O5 I don't think I need to break open the primary case again.
Your right and just hitting the watch thread button doesn't help my post count.You know what emoji I want to post but I'm refraining![]()
I have a Mastiff and if you can pull the clutch cover/belt guard off without removing the pipes your good on the pipes, I have to also loosen the back tire/belt to get it out of the way also, the drive pulley doesn't have to come off the tranny. Some say they lift out the battery box and lift the starter out the top, I prefer not to mess with all the wiring with it being zip tied together.Removing starter on 2005 Chopper. I think a recent noise I have been experiencing is the pinion shaft not receding properly due to grime. I want to remove it and do a full cleaning and replace what is necessary. I will also confirm that oil relief groove is cut in the half moon spot. My question is how much do I need to remove to get the starter out. Does the final drive gear housing need to come off? - Pipes? Since it is an O5 I don't think I need to break open the primary case again.
No the Ridgeback I worked on it came out the left sideYou mean the right side on pit/ridgeback not left![]()
