francoblay1
The Spaniard
Hey wanKER,Good one
Tell me what thread /dimensions, etc. do have our CRs again, please? Thanks.
I need new ones and I am not going to buy the same ones from S&S, too expensive... I will find some manual ones.
Hey wanKER,Good one
I don´t have access to an APO anymore... too expensive for me now to buy parts from the US.Just go with s&s always best to use the right parts
Here's the manual ones from S&SHey wanKER,
I do wear gloves!!!Here's the manual ones from S&SElectric ones are cheaper and when you go with the cheaper manual ones you won't be able to reach in the hole without burning your fingers.
https://www.amazon.com/Cycle-Compression-Release-MAN-COMPRESSION-RELEASES/dp/B000GVGGVK
I went to my local shop and got them from Drag Specialties thru him for $105 each and they come with the rubbers.There's a first lol, the manual ones are like twice as expensive as the electric ones.
I would have sworn the S&S were different thread pitch!!! Thanks Bro!!! Same deepness???Looks like they will work if you can activate them, not much lost if they don't at that price
S&S Compression Release Kit
If you built a big monster of a motor, you want it to destroy the pavement, not your starter. S&S Cycle's compression release system eliminates high compression starting problems. Designed exclusively for S&S cylinder heads, the compression release system consists of a small valve that opens during starting and allows a portion of the cylinder pressure to escape into the exhaust port. The reduced cylinder pressure makes it easier for the starter to turn the engine.
Features:
- Available in electric or manual styles for S&S heads that accept compression releases
- Electric compression releases open when you press the start button and close when the button is released
- Manual compression releases are opened manually and close when the motor starts
- Kits include the required parts for installation
- Thread pitch is 10mm x 1.0mm
- Made in the USA
Ok thnx, I'll try that tonight when I get home from work.Put your finger on the rear CR when you go to start it and feel if it pops back up while its trying to start, if it does pop up, push it down immediately. Even though they work when you push the start button, it doesn't mean it has the nuts to hold it down when the compression comes up in that cylinder causing it to close and you get the bang.
Hold the rear CR down with your left hand while starting the bike, that´s what I´ve been doing for the last year or so... since I broke a starter shaft!!!I think mine are gonna need replaced this winter. Sometimes the bike starts nice and easy, other times it's like the starter hit a brick wall and it has to muscle through to get her spinning.
OH ok... lol didnt read your post before posting mine! lolPut your finger on the rear CR when you go to start it and feel if it pops back up while its trying to start, if it does pop up, push it down immediately. Even though they work when you push the start button, it doesn't mean it has the nuts to hold it down when the compression comes up in that cylinder causing it to close and you get the bang.
Yeah....Someone else has broken his starter shaft also, but I forget who that was![]()
Don' know what u r referring to.. bike still spins over extremely faster then when my compression releases weren' working but I wasn't going to hijack this thread and add how my starter was making a huge clunk after a rebuild because it wasn' relivat to the topic Mr miyagiSo what has changed![]()
