Primary Leak
Tomtang
I've had a primary Leak for some time now. Few years back phatchopper helped me with removing my.inner and outer primary. At that time I replaced all gaskets and torqued everything back to specs. Lasted awhile then started again. I really kinda worn out with it. Thinking terribly about an open primary. Maybe I'll repair it again before I pull the trigger!! Any suggestions?
I found some old school brown liquid gasket maker at O'Reillys. Its helped stop my primary drips. Just my .02
Aviation Gasket Sealer #3?
That stuff is wonderful! Never hardens and just a little brake cleaner and it washes off with a paper towel.
Cant remember the name exactly, but the same properties. Stays a bit flexible but fills the gaps. I've flat filed my outer down to the nickel and it still dribbles like an old dog. This stuff stopped that....mostly. lol.
Tomtang
have you tried the new square type o-ring that Curtis sells at wild steed worx? Outter and inspection cover gasket.
No I haven't. I bought a complete primary gasket set from Curtis in early16 or late 15.
Sent from my SM-G950U using Tapatalk
Tomtang
Really shouldn't need sealer on primary o ring gaskets are you sure it's net the vent or the starter leaking.
Checked the vent and no it's not leaking.
I'm thinking about pulling the primary again and start and if no good results, then I'll purchased and open primary.
Tomtang
Will try and find some before I spend the big money!
Tomtang
I agree try that before you spend out the dough Or unless you've always wanted the outer primary like myself Then go for it
Sent from my SM-N950U using Tapatalk
Did you purchase the Primary? If so what kind? I think I'll take it apart again and give it another try! Thanks
Tomtang
The baker open primary is very smooth, check around your starter before you pull it all apart, and as far as the vent (I know you checked it) but it allows oil out and it collects on bottom of primary there should be oil residue near and below the vent if there isn't I'd say the vent is not working(plugged) and the starter is getting oil in it.
Ok thanks
Tomtang
Ok thanks
Just finished riding abit and I can see it leaking below the primary, down the length of it. Friend told it was leaking from the inner primary
When you do pull the outer cover, check to see if its flat? I bought a brand new cover and it had high spots all over.
Here's what I used to stop the drip...
phatchopper300
I just wanta ride
No I have not. Would if had the funds. I have put alot in the dog over the last 6 months and having it painted.
bigkelk9
Mine has been leaking since the Kansas trip in June. Drives me crazy.. but after speaking to Curtis and realizing how big of a job it is.. I'll have to wait a minute before doing it.. but the vent was the first thing I checked after Eric informed me of it.. Mine is leaking between the engine and primary too..
bdm7250
The Karata is smoother and far cooler.. :D
