roedog
I have an 03 Mastiff, it died on me the first time this past weekend. I felt it somewhat cutting out going down the freeway, but just thought it was a hicup. Well as soon as I got to the off ramp the Dog died I coasted off the freeway. I had to get it towed home to make it short $108. It was cranking over fine after it went down, until I killed the battery. But it would not run? I checked the spark all good, checked errors on the module under the seat, nothing. I verified I get a red light when I push the start button. So crank sensor seems ok? I left tender on the battery overnight, cause it only had 12.3VDC. Next day I had it up to 13.4VDC, and started it up and what you know it runs. Battery voltage increased when RPM's were turned up to 14.3VDC, so the stator seems to be charging ok. Verified coil, grounds, battery connections and etc. Took it for a ride yesterday, all good. Then after about 15miles it died at a red light. I got it fired back up, rode into a parking lot and it died again? Turned off the ignition, to reset everything. Then it started back up ok, ran the rest of the night? So my friend thinks I might have a bad ignition module? It does not seem like a fuel problem, because it just dies when it happens, I would think it would studder a bit if the Dog was not getting gas. Any thoughts much appreciated....
Sean
Sean
