Hirter6Pack
Not Quite A Guru
We have to pay the billsReading the whole thread helps
Just pull hard,more than likely the nubs will break off. Don't worry about it just put the new one in with a little soap and give a twist.I removed the seat just fine. I'm talking about actually removing the suction cups off the actual seat. Thx
Did ya try to lube it?I bought some extra cups, you know, just in case.... and sure enough I needed to replace mine. But no matter how much 'help' I gave that plug.... it just wouldn't go in all the way. So, I put it in the best I could then took a wood screw (small and tapered) and as I screwed it in it forced it in... all is good. The screw is counter-sunk enough not to scratch the paint.![]()
j/k, use dish dropsyea....... but all is good.Did ya try to lube it?j/k, use dish drops
I went back and looked at post #21. I see what the problem was. It was one of your post Dent and to be honest with you, I just don't pay any attention to them......My badRefer to post #21
