I hit the start button, the starter starts to turn, the bike does not turn over then after 2-3 seconds the speedo goes dead and all I hear is the relay clicking.
Yesterday I changed out some grips and shined up the bike well. I disconnected the speedo and dash, put everthing back together went to start and had some odd lights turn on, on my dash. Turns out I had connected it upside down. Re-connected it and i was good to go. Got home, turn the bike off and the above happend. I checked the batter and saw the negative terminal was a bit loose and there had been a short. The washer behind the bolt was a bit burnt and so was one of the connections. You can see it below. I charged the battery, got new bolts and after charging I was good to go. Woke up this morning rode for about 20 minutes, came back home went to take off again and the samething happend.
I thought maybe the battery had gone bad and was not holding a charge. I just tried another battery and my original had been charging all day. Nothing. I checked to see if any grounds were loose. All was good.
Don't know what causes the bike to stop the starter from spinning, shut down the speedo and then just click at the relay. The top little black box with lights on my battery lights up green when as the relay clicks. No red lights however.
