Crank but no fire
I know there's a bunch of conversations out there on this object. But I have not found anything like my problem, unless I missed it. My 05' pitbull will crank but I have no spark. I have 12.51 volts going into my ehc. And coming out to the coil (red wire) but the blue and yellow coming out of the ehc has no power. Even when cranking. I also do not have any lights that light up on the ehc it's self... but like I said I do have power coming out of it. Any ideas?
blacktopper
You might check the jst connector red wire to the module. I had a pin back out and lose contact and resulted in no power to the ignition module.
Had him check all that, because that was the problem mine had.
I'll send him a text, and see if he has ordered one yet.
HUGE thanks to Mr. Wright and Blacktopper! The dog is finally on the road with some minor things to finish on her. But after 10 years I took her for about a 5 mile ride and I couldn't be happier. Thank you all so much!
10 years! You better check the dates on them tires. That's a long time for them to be sitting.
