Yost Power Tube....Any thoughts?
yelladog
I put the xxx original booster in mine works great its all I need better throttle response better gas mileage 55.00 & 10 minutes of your time:2thumbs:
haze324
you have a Super G? I thought it said you getter better performance with an E? Did you do anything else to your carb?
yelladog
I have the G before they came out with the purple booster they used the original booster I think the difference with the carb bored out a wopping 3mm you get more top end witch with our motors I don't think we need I even kept the same jets I have open pipes with the washers in & it runs great.
surferdude
dry docked
:spank: :D I put one in and I really don't see a difference ... I'm thinking about removing it and see if I can still see or feel a difference ... It's easy to put in and take out ... just remove the bowl and unscrew the main jet ... in and out ....
