Electrical issue
phatchopper300
I just wanta ride
Ok now having issue electrical this time it's dealing with the CB keeps tripping during ridding so it's not charging battery then battery dies then bike shuts down. Not sure where to start. I guess start on grounds then each system I have1st gen rip kit 08 efi k9
Sent from my SM-N950U using Tapatalk
What's the voltage when charging?
It's possible the circuit breaker just isn't any good
13.8 volts with bike at idle. I might as well replace CB rule that out
Try running a fuse do you have a dedicated fuse for the RIP kit connected to the battery?
Check the ground on the VR it's possible it gets dirty as its grounded via the bolt into the frame.
phatchopper300
I just wanta ride
Another ? the relay for efi looks like horn relay what should the voltage be on relay(25 amp). The relay gets very warm during operation I know it has power to it with engine running I have had to replace it before Want to make sure it's the correct amperage Just wondering if that is flipping the circuit breaker
