I don't think thunderheart licenses the software except to dealers it's locked.Yep.. I've got the RIP kit and I'm looking for the cable and software that comes with the control module.. My module doesn't have the easy click adjustment, just a port for the cable..
You need to buy the programmable ignition if you want to change timing n the rev limiter. Or you can write your own also if you have the know how. DOC does have a hopped up program for his bike but you'll have to talk to JeffYep.. I've got the RIP kit and I'm looking for the cable and software that comes with the control module.. My module doesn't have the easy click adjustment, just a port for the cable..
I'd like to know exactly what the presets are for my module and get real time data log.. My rev limits according to the tach are lower than the 5300 average presets.. I'd also like to know what the advanced timing presets are, because I've had the carbs jetted, adjusted the carb in all manners, bumped up the octane levels. And it still falls on its face for split seconds, and has a semi dead spot between cruising and acceleration.. And it's not the carb pump adjustment either..I don't think thunderheart licenses the software except to dealers it's locked.
There is a programmable ignition which has 6 or 7 different preset ignition curves. That you can buy from thunderheart directly.
Just curious why you want to change it anyways?
Position Rev Limit RPMI don't think thunderheart licenses the software except to dealers it's locked.
If you expecting big gains from changing the program, your in for a let down. The only way to see a difference is if you have it dyno tuned to see the read out.Why not.. I guess.. it's the only thing electrical left that I haven't replaced..
Any updates on programming a non programmable ignition
Are you running the super G? If so, is it the newer or older model? The older ones had a drilled .040 air bleed. The new ones have changeable air bleed jets. My 04 is an older model and will NOT dial in. A Mikuni 48 is on my short list. JmoI'd like to know exactly what the presets are for my module and get real time data log.. My rev limits according to the tach are lower than the 5300 average presets.. I'd also like to know what the advanced timing presets are, because I've had the carbs jetted, adjusted the carb in all manners, bumped up the octane levels. And it still falls on its face for split seconds, and has a semi dead spot between cruising and acceleration.. And it's not the carb pump adjustment either..
