gasket replacement
sgrind1
i plan to go to an open belt drive or even an internal belt drive this winter,but for now i have to change the o ring coming from starter to primary.what all am i going to have to remove and is there any suggestions or anything i should do to ensure it want leak.
thinks for the help
haze324
I have a small leak there myself. Plan on just leaving it untill I change to an open belt hopefully. To change out the gasket between the primary and the starter....its more of ring that sits at the end of the jackshaft. Pull your outter primary, pull your clutch assembly, take out the jackshaft, take out the starter. Replace ring. And re-assemble. The whole process is listed in an HD service manual. Just grabbed a buddies and took a look.
dogvet
Banned
thinks for the help
There isn't a starter o-ring on a 2003 Pitbull. There is a lip seal that the starter jack shaft runs through.
If you have (or have a friend) who has a harley softail service manual (something in the 1992 range). The repair procedure is pretty well laid out and the bolt torques will be correct.
The jackshaft seal installs with the lip of the seal facing towards the primary.
As far as geting the o-ring to seal apply a thin bead of silicone RTV to the o-ring groove on the inner primary.
Getting the gaskets to seal properly on all of those chrome surfaces can be a real pain.
BDM used gaskets form an outfit in Arizona that makes a killer gasket for the primary and inspection cover.
Contact these folks and they will either provide you with what you need or tell you who you can get them from in your area.
Innovative Sealing Solutions, LLC
2432 West Peoria Avenue
Suite # 1186
Phoenix, Az. 85029
(602)944-4250
(602)944-4529 (Fax)
gasketgirl@innovativesealingsolutions.com
Call them and ask for Kim.
Their gaskets and seals are the only ones I will use on my bike!
delly2
Banned
wait a second ,if i want to replace the oring on my 05 starter i have to pull apart the primary covers,clutch pak and hub,to get to it? i thought i just had to pull the starter to get to this seal?
1968 Nam
Think this is my problem also, oil on final drive belt and lower swing arm. Also on wifes shirt.
dogvet
Banned
You don't have to pull the clutch on any model or year Big Dog to remove the starter! You don't even have to pull the primary cover on 05 and up Dogs.
On 04 and earlier you have to take of the primary cover to access the jackshaft bolt.
