Headlight/High Beam
roadhogg
Hey just looking for some ideas for a problem or if anyone has experienced it before,the headlight on my 09 K9,the high beam light when you flip the switch on for it,it lights for a few seconds then goes out after flipping from low beam,any ideas,thanks
PROFLYER
SWOLE
the indicator light or the high beam itself goes out after a few seconds? What type of bulb are you running?
bigkelk9
Willing to bet ur light is going out.. if ur controls are operating as they should.. that's what's going on no doubt. Just happened to a buddy a few months back. I was with him when it happened
Replace the bulb as others stated
Also when you replace the bulb, crimp the connectors in the plug, so it fits tight. A loose connection will create heat and burn the plug.
Gmutoagrsv
I was having a problem where I’d start the bike and the low beam would come and stay in. I’d hit the switch and nothing would happen. The indicator would slowly blink. I was told possible ehc issue. So I sent it off to be tested. I’m hoping that is what was causing it.
SimpleMan_Omen
I just bought a 2003 Pitbull that the high beam wouldn't turn on. I narrowed it down to being the EHC (Thunder Heart). I spliced the wire before the EHC into the wire after and it now works. The blue high beam dash light even comes on after doing so.
