PROFLYER
SWOLE
What? That was in response to Ker who said to put them in later through the valve stem. It's possible but a pain in the butt if the stem is narrow which some are for some reason.what are you implying, I polish the bottom of my motor
I can't get beads through the stem on my k9 the hole is too small. I need to replace the valve stem one of these days but I bought the 90 degree ones and that would be impossible to get them through.What? That was in response to Ker who said to put them in later through the valve stem. It's possible but a pain in the butt if the stem is narrow which some are for some reason.
Patience grasshopper, if you use the tube n little bottle, you can tap the tube with your finger n they march right in the one after the otherI can't get beads through the stem on my k9 the hole is too small. I need to replace the valve stem one of these days but I bought the 90 degree ones and that would be impossible to get them through.
I was taught a very easy way to quickly install Dyno beads. You can put a whole package in in 15 seconds. Once you have the valve stem out, the plastic tube in place,& the bottle attached. Turn bottle upside down to start pouring. NOW with your other hand pick up a vibrating stencelor and touch the side of The vibrating wand to the rubber hose about 1/2" from the valve stem. NOT the wand point but the side of it. Dyno beads will drop right in the tire. I run them in all my trucks, RV, cars, & bikes.Nope...doesnt work. I know how to do it I can do it on all the other 3 big dog tires except for the rear of the k9 when I replaced the tire I noticed the hole was very smallPatience grasshopper, if you use the tube n little bottle, you can tap the tube with your finger n they march right in the one after the other
I understand your problem the stem is too small, but for normal stems where the beads fit this is a very easy & fast way to load a tire.Nope...doesnt work. I know how to do it I can do it on all the other 3 big dog tires except for the rear of the k9 when I replaced the tire I noticed the hole was very small
It's not the inner core diameter. Next tire change I'll take a pic.All stems take the same inner core valve
Try putting them in without the air in the tire![]()
