Both of them threads are great threads, but don't cover changing the oil while the forks on on the bike. Let me try to explain a how to. There are a couple tricks to get it back together.
1. lift the bike and remove the front wheel
2. On the bottom of your fork tubes, the little pointy things are held on by a set screw. Remove them.
3. Up through that hole is a socket head cap screw bolt. Remove that bolt. Oil, and sludge will drip out.
4. Remove the cap off the top of the forks. Wrapping the inside of the socket with tape will help protect the chrome.
Note: there is a spring in there, but nothing you can't hold down with your hands.
5. Take some brake cleaner and spray down the tube, to clean out the sludge.
6. Now for the tricky part, getting that bolt restarted in the bottom. I use a long wooden dowel rod, to slide down the inside of the tube, to push on the part the the bolt screws into. It has a spring on the bottom too, so the bolt won't reach.
Put a dab of silicone on the head of the bolt to seal it.
7. Add 10 oz of oil in each fork, and put the caps back on.
8. Reinstall the little pointy things on the bottom.
9. Reinstall front wheel and wipe all your finger prints off.
That should do it.
