Slowrider,
NOt sure how you got 32oz or for that matter made a pint into a quart, but regardless, pretty sure the 6sp Baker only takes 20oz as pre the O&M and even on the Baker site, they only recommend 23 with the new recommended Spectro (?). If you are putting in 32 oz, you may want to verify with the O&M or SM or dealer. Hopefully that ghost of Thing will confirm also.
Josh do recommend that you stay away from the synthetic in the primary. Mobile 1 and other high quality V-Twin Specific Synthetic are okay for engine after break in. On the Tranny many use Redline Heavy or V-Twin Shock Proof (personnaly still holding out on that one) but the regular RevTech or Redline Transmission fluid work good also (the non shockproof).
Key IMHO is to do regular oil and filter changes regardless if it just good ole dino or a synthetic. Maintenance is key to keeping these Dogs happy and living a long life. Fluid changes are cheap and should be able to change all fluids for $50-$60 at most if you turn your own wrench.
If not would get a service manual, some good tools and start learning the ins and outs and do not be afraid to ask you dealre questions.
Welcome and have fun but be safe.
