Charging issue.
Hoodlum502
Hey guys, I'm not only new here, but new to owning a Big Dog. I bought a 2007 Mastiff in January, and I am having my first problem. I leave a tender on the battery anytime that I'm not riding, so the each ride starts with a fresh battery. After a few starts, and about 75 miles or so, my bike won't start, so it's definitely something going on with the charging system. My question is...has anyone else had charging issues, and is the voltage regulator the best place to start when replacing parts? Thanks in advance!
keverett91507
I went through the same thing before but it was my battery. It would charge on the trickle charger but not enough left to keep it up. Just a thought but make sure your battery is good before you go changing parts like I did. I learned KISS keep it simple stupid and now I check the easiest parts first. Any auto part store will test the battery for u
Hoodlum502
Is it charging when its running?
No. It is not charging when running. I forgot to mention that I already purchased a new battery because I thought it was a bad battery.
Hoodlum502
I
I'm sorry, I should've mentioned in the post that the first thing that I did was buy a new battery because I thought it was a bad battery. So, yes the battery is brand new.
Hoodlum502
Also check the circuit breaker,if it has one ,my is under the seat ,years ago happened to me ,where I thought it was the charging system,if you installed the new battery check if its charging properly,my is 12+ volts at idle and 14.3 with a crack of the throttle
Definitely will check these things. Thank you.
glennpg
Ran into the same problem this past week. Got on the road and battery went dead after an hour on the road. stopped at a Harley Shop, changed the battery and mechanics tested the charging system at the battery, he said is was not charging and that is was probably the stator. I will check the VR and also check to see if there is a breaker under seat before moving on to the stator. Thanks
BadDawg Bill
Ya, fookin Harley.... Let's put in our over priced battery and THEN check to see if it's charging..... Typical....
Hoodlum502
I got my new VR last week. Put it on and wired it up. Problem fixed. Turns out that the regulators that Big Dog used on their bikes are junk and a lot were recalled. Apparently any time that you jump your bike with those VR's with a running car, you fry them.
Ran into the same problem this past week. Got on the road and battery went dead after an hour on the road. stopped at a Harley Shop, changed the battery and mechanics tested the charging system at the battery, he said is was not charging and that is was probably the stator. I will check the VR and also check to see if there is a breaker under seat before moving on to the stator. Thanks[/QU
shansel88
I'd never recommend jumping a motorcycle with a "running' car. You should have no issue jumping a bike with the car - not running. (exception V8 motor bike) This is usually a safe scenario for most bikes. And if you cant start it that way- then you got other issues anyway-shorted wires/etc/ Just my opinion
Big D Florida
Food for thought...
The VR (vent regulated), or "gel cell" batteries, as some call them, are very similar to deep-cycle batteries in their contruction and charging requirements.
Low amperage input is called for in the specs, the plate configuration will not withstand high current rates.
This applies to any battery of this type (trolling motor, rv, golf cart)
