You could make 5 outta aluminum in the time it takes to make 1 outta SS, but how would you know that? You only rub metalSo what![]()
I think you're giving him too much credit..You could make 5 outta aluminum in the time it takes to make 1 outta SS, but how would you know that? You only rub metal![]()
Mine is already doneShannon could probably knock out 5 stainless steel ones in the time it took to make your 1aluminum one, figuring the polishing time involved. Let's find out, ready guys? Ready , set, GO!!
and I only used 1 tap
Hey! You jumped the gun ! I didn't say GO yet . Now we gotta have a restart ! Ready, Set , Aw never mind.Mine is already done![]()
In aluminum, impressiveMine is already doneand I only used 1 tap
1 tap, 6 drill bits, 1 hammer , and 1 chisel ! But it still looks pretty decent !In aluminum, impressive![]()
Forgot the hack saw,1 tap, 6 drill bits, 1 hammer , and 1 chisel ! But it still looks pretty decent !
You'll be lucky to get away with 1 tap in SSDid someone forget to tell you? I'm good. I wear out more taps than break them.Forgot the hack saw,You'll be lucky to get away with 1 tap in SS
No problem! Drill 3/8 " hole , slip 5/16" tap in and run a5/16" nut on it. Just make sure the tap handle is good and tight! Should work --- I think?Forgot the hack saw,You'll be lucky to get away with 1 tap in SS
You da manDid someone forget to tell you? I'm good. I wear out more taps than break them.
I'll urn them out on a CNC plasma. It will take about 20 seconds to burn 12 of them. It will take me long to clean up the edges than anything else.![]()
I'm retired
I spoke with Donna and Derek and the one they sell requires all new hardware on the shield. Shannon is making a part match replacement out of stainless which will fit right on and never break.Ya don't need stainless, just make the improved design like Derek sells. I made this one outta aluminum but its similar to the new improved one.
