Gen 2 RIP install
Ok so this might sound like a dumb question but where does the double red wire on the GEN 2 RIP kit get attached to. the old EHC was connected directly to the battery but the directions for the RIP kit say connect it to the circuit breaker. Where is the circuit breaker?
Little gray box, your VR should be feeding to it as well.
But I would run a separate 30 amp fuse rather than use the breaker
Anyone put one of these on a mastiff. Don't know what I'm missing but when I put the ehc in according to instructions this is what it looks like and there is no way my side cover will go on.
phatchopper300
I just wanta ride
I moved my ecm (silver box) forward about 1 1/2" to clear the side cover back end
Sent from my SAMSUNG-SM-G935A using Tapatalk
phatchopper300
I just wanta ride
I moved my ecm forward about 1 1/2" so my side cover back end would fit with out binding
No problem with interference at the front with the cover?
No I just tested it to make sure they would be no interference and it loosened up all the wires going into the ECM before it looked like a very tight snake too much Bend in the wires it's all good now
