Wire plus turn module delete??
JMont
I have a 2003 Mastiff with the wire plus kit. I burnt out the turn and brake module and am curious if I can wire a new module in or would be better to go back with the same thing. Im certain this is an amateur question but am hoping for input on the most inexpensive but best reliability module to replace?? Thanks in advance
TapioK
Cheapest would be a new WP brain, about $250 I think. Interesting might be a M-box v-2, a German unit for about $350. Dentdude will chime in soon and tell how you will see the light with Alex's EHC for about $500. He is a firm believer it will also fix your hemorrhoids.
Bill will tell you to hardwire the bike old skool...
All but new WP unit will require some work on wires since your harness has been modified for WP.
Can't really go back to Axle units unless you buy a harness since his is all cut up. Add $300 to axle EHC and it now becomes very expensive. With a 1980's DOT matrix printer cable.
Look familiar?
TapioK
Look familiar?
Agree, that is why I said new WP brain or Motogadget first.... or cheaper Thunderheart unit would work as well. What I like about m-unit is no stupid connectors.
JMont
All I need is the module for turning lights. I can get it thru wire plus for $145 shipped. If i go any other way i think will be more trouble than its worth just from tracking the color coated wires to properly rewire. I was hoping someone would know of a turn module that might be better but again cutting n tracking tosave a few bucks wont be worth just plug n play for $145
Are you sure it's the turn signal that went bad? Never heard of that one going bad because there really isn't much power too it.
My power module went bad, I actually have the turn signal module I can send you. I am nearly certain it works but you can test it and If it works send me what you think is fair for it.
JMont
Yes i am certain its the module. My ground on the battery came off and shorted it out. I can smell it burnt. If u could do that I would be so grateful.
JMont
What bike did you have it on. And that would be so awesome. Mine is a 13034 wire plus module. Its for sure bad from a bad ground, u can smell it fried
I just checked the wires plus website..mine is #13014A it was on a 2004 dog. Guess it won't work I checked the wires plus website and they look very different
here is mine
Nope different connectors... Sorry man.
I was hoping someone could use this damn thing too been sitting on my shelf for almost a year.
I didn't even realize WP made a 03 big dog unit until now..lol
JMont
Could it be spliced? If number of wires n colors are the same i could cut plug n splice
JMont
I must say it is a very very rare occasion that someone would just nd that without needing the whole set up. I got really lucky to have not fried the whole unit.
It's got more wires coming out then you got there. Mine has two plugs it's also setup for momentary switching not latching. Since I have push buttons on my 04 controls and you have the Harley style rocker switches. I'd say these are not compatible.
JMont
Your right. I didn't realize 04 had the new switches. I really appreciate you taking your time to check. Thanks anyway. That would have bn awesome.
Tim Brown
Hello all, I'm new (tim) and live in se Minnesota. I recently purchased an 07 k9 last summer and only put a few hundred miles on it. And this season I had put around 800 miles Adams my ech unit fried. It's the Wire Plus #13014A unit. Does anyone know where I can get my hands on a replacement or am I better off going with a while new kit (which would mean new harness connectors I'm assuming). Please help if you can thanks in advance
