Ignition Switch
Jcomps
Hate to hijack but, before I start cutting wires I wanted to be sure. Original is a 3 prong Letters are IG, B, L and the tractor supply has black wire and yellow wire. I "assume" IG and L connect to yellow and B connects to black?
PacoPetty
That’s a good question!
tilemaster
Well I tested the switch it works fine. 2009 k9 may be time to get rid of the EHC.
I have an 2004 pitbull and mine did the same thing so I got a wire plus system and re wired my bike in 1 day, just beware I cut all the wires off the echo and I had to test every wire for its function but the wire plus system comes with a diagram to wire which has numbers for every wire and on the each plug there is tiny numbers to correspond with the diagram and no problems after retire. Good luck
