I'm assuming u have the original wiring is what I was getting atI have the original switch the came with the bike. 2009 k9
Are you saying the bike is completely dead, no lights or anything?Any thoughts on a problem I'm currently having. When I turn on the ignition switch nothing happens. later when I try it everything works fine. I'm wondering if it's the switch. I'm no good at electrical problems need all the help I can get.
He just said he don't know n e thing about electrical or I woulda told him to use a jumper with some gator clips.. damnit Ker ya don't listen either!!! BahahahahaAre you saying the bike is completely dead, no lights or anything?
If that's the case, unplug the switch and use a small paper clip to jump the connector to see if its the switch before replacing it.
Is that the only thing that don't work?I found the tread on the switch from tractor supply I will jumper the switch. The speedo will not turn on and sweep. Then it will work fine.
Hey everyone knows what a paper clip isHe just said he don't know n e thing about electrical or I woulda told him to use a jumper with some gator clips.. damnit Ker ya don't listen either!!! Bahahahaha![]()
If you want to stick with a BDM switch, DOC's has them.Thats it, I'll get done THANK YOU
The switch from Tractor supply was a direct fit with nothing to modify to install except the wire splicing and its been in for 2 years and it has never fallen out. But DOC does have the OEMI will test the switch and go to Tractor supply if the don't have one I will check with DOC's
Might just be my OCD but I really prefer keeping as many BDM parts as possible.The switch from Tractor supply was a direct fit with nothing to modify to install except the wire splicing and its been in for 2 years and it has never fallen out. But DOC does have the OEM![]()
I still have mine, ya know why? cause it wasn't my key that went bad and no one advised me at the time to jump it. So I cut it out and then replaced my EHC with the ESC, problem solved.Might just be my OCD but I really prefer keeping as many BDM parts as possible.
Haste makes waste...never heard that?I still have mine, ya know why? cause it wasn't my key that went bad and no one advised me at the time to jump it. So I cut it out and then replaced my EHC with the ESC, problem solved.
