Wheel bearing question
just replace the wheel bearings on the sled.
The front wheel is allot tighter than usual it does spin but I am noticing quite a bit of resistance.
It is not binding and no noise noticed but is this normal for new bearings to be tighter?
Thanks,
Paul
If the bearing didn't quite get seated all the way in the hub I could see it being tighter.
Obviously incorrect size bearing would do it too...but I assume you double checked that? I don't know the sleds bearings but on the dogs the bearing #'s have to end in "RS". And the RS stands for American size or 3/4" axle. I'm just letting you know, cause it's kinda confusing. For us there is a 6204-2-12 and a 6204-2RS-12. One will fit right while the other won't.
blacktopper
I think the 2 RS means 2 Rubber Seals (one on each side) the 12 is the sixteents. (12/16 =3/4)
Think your right there. So the 6204 2RS is wrong one that must be the metric and the 6204-2RS-12 is the right one.
I've been wrong before, not the first won't be the last!
Thanks Rodger that makes more sense. I should have known actually since the 6204-2ZZ is the metal shielded one vs the Rubber Seal. And the 16 is the rear with the one inch. 6205-2RS-16
blacktopper
I just bought 2 of those fronts to have in stock. Pricey little things. $29 from Timken:-(
The bearings seem fine. I honestly think it's the rubber seals that are extremely tight around the spacers. I am going to take the wheel back to the shop that installed the bearings.
Thanks all for sharing your knowledge.
