Jet sizes?
Not sure what is in it now. I haven't taken it apart yet. Just recently got the bike. It had no baffles when I got it and it was a bit louder than I like. I put a set of baffles in an now can't get it to run rite. Tried to adjust carb according to s&s instructions but when I tried to lean it out it never wanted to stall with the idle mixture screw all the way in. I don't know if someone damaged the carb or its messed up from sitting a long time. I figured I would replace the carb with a new super g and at least I know I'll be starting from square one with the carb. That's why I was asking about the jets. The ones that are in there may not even be the rite ones
When I purchased my bike the dealer install the 2 into 2 and the jets that came with the pipes were 31 and 76
When you say not run right, what exactly are the symptoms?
Seems to flood out on cold start. If I change the plugs it starts up but idles rough until it warms up.
I would check your carb settings first, may not be getting enough fuel at first. How does it idle? Any changes in idle rpms? What rpm range is it running in when idling?
Sorry for all the questions just trying to get an understanding of what your bike is doing.
Butch Cassidy
I have a 107 and also run 31/76 ... but that is what xXx carb put in when he updated my Super G carb. You might want to talk to him before you do anything.... he is a wealth of knowledge.
Update on jet situation. Haven't replaced carb wanted to try switching the jets first. Pulled carb apart it had a 32 & 84 . I switched it out for a 31 & 76 . Took bike for a ride and once it warmed up it seemed to almost want to stall when I gave it gas. When I tried to adjust the idle mixture screw according to instructions turned all the way in had really no affect on the idle. I'm pretty new to this so any recomendations
would be appreciated .
Butch Cassidy
.. have you adjusted the accelerator pump..? If that is too lean it will cause a stall ... but first, go back to the standard settings for idle speed and mixture and pump. The best place to start is the beginning. You can set these three things with the motor off; and it should start... and take it from there....https://www.sscycle.com/docs/default-source/default-document-library/carbtuningguide.pdf?sfvrsn=2
See if this will help you
francoblay1
The Spaniard
I would first check the float/fuel level and replace the fuel mixture screw as they wear out.
Also make sure the little blue O ring is where it is supposed to be and then do your carb adjustment.
By the way have you checked the rubber cap on your intake manifold? It might be perished.
This article is very good to read too.
http://www.bikernet.com/pages/story_detail.aspx?id=7153
Paul.
:agree:
@John Cingel Check this out too: http://bigdogbiker.com/threads/what-jets-do-you-run.14439/
