Needing expert help on electrical
phatchopper300
I just wanta ride
I actually have two circuit breakers one for the EFI and the other is for voltage regulator
Sent from my SAMSUNG-SM-G935A using Tapatalk
Are you running an led headlight or the original h4? The headlight may have shorted out if it's an h4, I know that can cause havoc with an ehc setup not sure what effect it would have if any on the rip
Does the Rip have a fuse link to it? do you have any lights?
Did you by any chance try a different battery, or disconnect the lithium and try cables to you car, not running of coarse. Maybe the Lithium took a shit, just throwing things out there.
I have a 2008 K-9 EFI have never had any electrical issues until about three nights ago went for a quick ride heading down interstate at about 75 miles an hour and it was like somebody took the battery out of the bike no power whatsoever power never return tried turning the key wiggling the key all electrical connections tight headed trailered home have gone through the bike in every direction I know how and I'm baffled I still have no power whatsoever battery is a lithium ion and is very strong low test perfect any help would be appreciated in any direction
Is there a RIP installed? I didn't see that mentioned by the OP
ground pounder
Those little circuit breakers have the button hid on the bottom side of them if they are the gray ones. They are hard to see. Some times they trip half in and out. Don't ask me how I know!!! LOL111
phatchopper300
I just wanta ride
No I have the H4 bulb but getting ready to switch over to LED
phatchopper300
I just wanta ride
The circuit breakers I have our Auto reset there are no buttons to push
Jersey Big Mike
100K mile club
check the key and see it work using a multimeter.
Check all the grounds going to the RIP.
It sounds like rip is not getting power.
You can do an old trick and use a pin to prick the insulation on the power line to the rip and connect the mulitmeter to that. If you do this over that small pin prick with heat shrink tape, electrical tape or spray on electrical tape (my preference for this). You can also use the pin trick to get to the connectors on the jst connectors.
phatchopper300
I just wanta ride
When I test the key ignition with the key off the multimeter reads zero when I turn the key on the multimeter reads the battery voltage which is 13.8v
Jersey Big Mike
100K mile club
You need to check that power is getting to the rip thru the harness and that all the grounds on the harness are ok.
If that all passes I'd begin to suspect the RIP although that would be the first failure I've heard of.
If I can free up some time I'll see if I can make a run that way and take a look.
phatchopper300
I just wanta ride
I have a new ecm on the way unlocked I want to try that also I've got a busy weekend this weekend but will be digging deep into it on Monday
ground pounder
Hey phat. Write jason from kansas motorcycle works a private message and explain whats going on with the rip kit. I think he helped develop the rip kit. He is on this site but i can't remember his screen name! CRS you know! Hopefully some one will chime it with his screen name. It will be hard to diagnose without a diagram.
phatchopper300
I just wanta ride
Okay will do thanks for the heads up I'm taking the battery now to have it tested also with a load on it
phatchopper300
I just wanta ride
Okay just did a test on the battery battery tested 13.76 volts at 381 cold cranking amps I guess I can check the battery off for being an issue
phatchopper300
I just wanta ride
Ok I replaced vfi unlocked and CB I now have power restored but now have no spark or fuel. I tested both with vfi and both work. ??????????
Also when I hook up protune all the tables are blank and I suppose once the bike is started it will learn all the maps problem is to is I have about five DT codes
ground pounder
Hey Phat. What map did you download in the new module? If you pm me your phone number I can walk you through the download if you want! I prefer the big dog off road map. You have to be care full which map you download as some will lock an unlocked module!!! What codes did it set?
