So would you increase the intermediate jet or the main jet or bothPopping on deceleration is caused by a LEAN condition. When you suddenly close the throttle, the incoming air is choked off and the closed throttle also causes the bike to return to idle on the very lean idle circuit. However, momentum of the bike is actually "driving" the engine in a sense, and that engine is still spinning at rpm that needs far more gas than the closed throttle position can provide. The engine is still spinning but the incoming fuel rate is very low, until just enough builds up in the combustion chamber to "fire" on the exhaust stroke of the engine.
What have you done to your bike? Exhaust, cam, etc.?So would you increase the intermediate jet or the main jet or both
I changed the exhaust and the air cleaner. I used to have mean mothers and stock air cleaner and I installed hooker headers Darkside big radius pipes and an S&S Dual RunnerWhat have you done to your bike? Exhaust, cam, etc.?
Okay thanks I have .032 and a .076 and I was wondering if I should try the .033 and .078 combo.Try .32 intermediate and .78 main I also had mean mothers and those were the jets recommended and I put a paul yaffee phantom pipe on and spike air cleaner and they also were the perfect match , with the dual runner you may possibly need .33 int also be sure and adjust the carb very simple process only takes a few minutes
Before you do that, did you try removing the Auxiliary bowl vent and readjusting the carb? look at the PDF, its #14Okay thanks I have .032 and a .076 and I was wondering if I should try the .033 and .078 combo.
Why would I do that I am running a S&S Dual Runner and it has the bowl vent built into the assembly. Does it need more venting than that?Before you do that, did you try removing the Auxiliary bowl vent and readjusting the carb? look at the PDF, its #14
With aftermarket air filters, this should be removed
Hooker Headers Darkside Big RadiusWhat pipes and air cleaner are you running?
I am running the BR and the dual runner also with the vent removed because that's what they recommend you do, I tried 32 and 78 and at while cruising at 50-55 it would sneeze thru the carb, per their (S&S) carb adjustment guide, they recommended to bump up the inter a size, that's why I'm running 33 and 78 now without any hickups.Why would I do that I am running a S&S Dual Runner and it has the bowl vent built into the assembly. Does it need more venting than that?
Okay thanks I will set it up today with a .033 intermediate jet and a .078 main jet and I will pull the auxiliary bowl vent. I will let you know what happens tonight. Thanks againI am running the BR and the dual runner also with the vent removed because that's what they recommend you do, I tried 32 and 78 and at while cruising at 50-55 it would sneeze thru the carb, per their (S&S) carb adjustment guide, they recommended to bump up the inter a size, that's why I'm running 33 and 78 now without any hickups.
You ask why would you do that? because its not running right now. Follow the istructions they have on the PDF, what you have to remember is no 2 bikes are a like because of tolerances, think about it, from .032 to .033 is .001. What if the tolerance is +/-.0005, you could have a .032 at .0315 and a ,033 at .0335, that's .002 difference. Is that going to make a difference? You bet it is.
Please do, we like to hear a happy ending
Let us know how you make out.Okay thanks I will set it up today with a .033 intermediate jet and a .078 main jet and I will pull the auxiliary bowl vent. I will let you know what happens tonight. Thanks again
Hey guys it's awesome!!! I put the .033 in and removed the auxiliary bowl vent plug and it runs like a raped ape!!! As for the deceleration popping it's gone it's more like a gurgle or growling I would say a growling and its not that bad of a growling so thanks to all of you for your support and help I really appreciate everything that you have done for me.He said he would so back off there chucky!
Yes I tuned the carb and put it through all the tests and It is perfect!!!Great news! Did you also dial in the carb?
Thanks for the update..Hey guys it's awesome!!! I put the .033 in and removed the auxiliary bowl vent plug and it runs like a raped ape!!! As for the deceleration popping it's gone it's more like a gurgle or growling I would say a growling and its not that bad of a growling so thanks to all of you for your support and help I really appreciate everything that you have done for me.
