chacha Chaff Your EHC!! Calendar Participant Mar 18, 2017 #22 Back on topic -- you have the ability to do the correct action. REMOVE the cap, work the action manually, lube if needed, and then replace the cap. More work -- yes, but you're not damaging the protective cover. Always worked for me.
badyellowvette Active Member Mar 18, 2017 #23 I slit mine enough to lube and put a dab of silicone on it. I just peel that off to lube next time.
njbiker20088 Active Member Mar 18, 2017 #24 badyellowvette said: I slit mine enough to lube and put a dab of silicone on it. I just peel that off to lube next time. Click to expand... I will do that.
