njbiker20088
I seen some people make a hole in the rubber boot and put wd40 is that true. and should I do that.
how long has it been since you did that and have there been any adverse effects?I did, but its a small slit not a hole, enough to get the straw to the WD-40 in it. Give it a squirt on the shaft and work it in.
t/k I will put on my list to do when I can see grass all I see is snow .I did, but its a small slit not a hole, enough to get the straw to the WD-40 in it. Give it a squirt on the shaft and work it in.
some say it helps them last longer ??? if it dose its a shot of wd40 is for me.how long has it been since you did that and have there been any adverse effects?
I usually hit them 2 or 3 times a year, and I've been doing it for at least 4-5 yrs, sometimes I can feel the carbon build up because its not smooth, so I work it with WD-40 until its smooth, No side effects because the slit is like the one on the tip of your wiener, and that don't let debris or water in now does it?how long has it been since you did that and have there been any adverse effects?
did yo' momma drop you on yo' head when you was a little boy??????????????????No side effects because the slit is like the one on the tip of your wiener, and that don't let debris or water in now does it?![]()
Ha Ha Ha Ha,,,did yo' momma drop you on yo' head when you was a little boy??????????????????![]()
Ker said "Wiener""
Giggle, Giggle !!
Guess you're not using a catheter yet! Good. I thought you would be at your age.I usually hit them 2 or 3 times a year, and I've been doing it for at least 4-5 yrs, sometimes I can feel the carbon build up because its not smooth, so I work it with WD-40 until its smooth, No side effects because the slit is like the one on the tip of your wiener, and that don't let debris or water in now does it?
I suppose you could get water in it if you directly hit it with a garden hose or power washer, but normal driving in the rain is not going to get in thru the slit.
I can't say for sure, but something happened
No catheter yet, but I do travel with my own personal nurseGuess you're not using a catheter yet! Good. I thought you would be at your age.
and I do like playing a very very bad patient
He goes with the depends..Guess you're not using a catheter yet! Good. I thought you would be at your age.
Well that DEPENDS, no pun intended, on how far I'm ridingHe goes with the depends..![]()
Riding?..You can be sittin on your couch for a matter of five minutes and have an oops..Well that DEPENDS, no pun intended, on how far I'm riding![]()
Just remembered, this thread is about a different kind of Compression Release !!Hey my mamma always told me to put on clean ones when ya go out, ya never know when you could have, I mean be in an accident.![]()
