roedog
I know I read some issues with the S&S 107 having oil blowing out the air filter. I'm having this issue with my 03 Mastiff, where do you find the puk cans, filters to replace having it attached to the back of the carb plate? It's making a mess on my push rod covers and engine from the oil dripping from the air filter cover. Somewhere I read it will do this if the oil level is high, I put little less then 3-qts in ahwile back, the manual says it holds 3-qts. Maybe I should put 2.5qts. next time I change the oil? Any help is much appreciated.
Thanks,
Sean
Thanks,
Sean
