Thanks for the reply. The previous owner told me that he just rebuilt them but the are leaking. The "Harley shop" tech stated that he didn't think they could be that they are just wore out and to check drag specialties. Anyone know where I might get a set?.Mike, you're shocks may be rebuildable. If they are like mine they can be sent back to the factory and rebuilt.View attachment 40623
You got an older dog Should be any shock for a Harley softail late 80 early 90's that you fancy should work.Thanks for the reply. The previous owner told me that he just rebuilt them but the are leaking. The "Harley shop" tech stated that he didn't think they could be that they are just wore out and to check drag specialties. Anyone know where I might get a set?.
A vendor on here sells some too
http://www.wildsteedworx.com/index....ucts_id=1326&zenid=sk6kneckbtfgbfdo9ncs8r2rk5 <-this link will those fit? Here is a picture of mine. Thanks just don't want to order the wrong ones.
Don't know for sure. Frank is the man with the older dogs.
These are just like mine (i.e. Frank's). They are Works Performance shocks. http://www.worksperformance.com Pretty sure one could get on the phone with them and they would walk you through how to size them.Mike, you're shocks may be rebuildable. If they are like mine they can be sent back to the factory and rebuilt.View attachment 40623
I know this is an older post but are these shocks mounted upside down or is it just me.
Definitely easier to adjust that wayI know this is an older post but are these shocks mounted upside down or is it just me.
Not all shocks are meant to be mounted upside down. Looks like its right side up to me. However having the adjuster on the top is kinda an eye sore.Definitely easier to adjust that way
And the 2 adjusting nuts and bare threads aren't, just an opinion.Not all shocks are meant to be mounted upside down. Looks like its right side up to me. However having the adjuster on the top is kinda an eye sore.
? Huh? Yes I agree the whole adjuster on the top is an eye sore including the bare nut/threadsAnd the 2 adjusting nuts and bare threads aren't, just an opinion.
The tension adjuster is on the bottom in the picture. The ride height is on the top/ I just thought they were upside down. I put my burly shocks on the streetglide in the opposite orientation.? Huh? Yes I agree the whole adjuster on the top is an eye sore including the bare nut/threads
Sorry...think my comment was confusing.The tension adjuster is on the bottom in the picture. The ride height is on the top/ I just thought they were upside down. I put my burly shocks on the streetglide in the opposite orientation.
Got mine for a Dyno and have worked out real well. 11 1/2 in. Could go to a 12 in with no problem.I need to replace the rear shocks and need some advice on what is available for my old dog. Thanks in advance. I also need to replace the left gas cap.
