Lifters an 585 cam
Bdawg12
So I have a 08 k9 it has 19,500 miles on it s&s recommends to change the lifters. While I'm there going to do the cam as well is there anything else I should do while doin this upgrade? Also where is the best place for these parts does it come as a kit or not? I looked on s&s website didn't see either one of them there. Thanks in advance for the help.
Www.wildsteedworx.com
Has all the stuff you need.
If your going to replace the lifters you'll need to either take your rockers off or go with quickee pushrods and cut your old one out. I recommend getting the quickees and cutting them out then you'll always be able to do lifters without touching your rockers. Saves lots of time and money.
Get new tappet gaskets and Cam cover gasket too. Curtis has everything you need.
Personally I don't recommend the limited travel kit lifters more expensive and more time consuming to adjust for not any benefit on a mild stock motor but shoot Curtis an email and he can probably get the lifters without them.
He has everything you need at a great price
Bdawg12
Thanks for your advice I surely appreciate it an i will check that website out.
Sent from my SM-G920V using Tapatalk
I personally would go directly to S&S and get the parts from them.:2cents:
Bdawg12
Update!!! got parts just waiting for the guy to finish a bike he's working on currently. So ready to get it done got the parts from s&s
Saved a few bucks. Thanks again for the advice
