Electric problem
bikeone
Hi together,
Think i have an EHC problem in my pit bull.
malfunctions are brake light front - right side flashers - sometimes need decompression by hand.
If engine runs, only one red intensive LED burns and flashes on the EHC.
maybe a defect of front brake light sensor and a defect of the front flasher?
cable Trouble?
Good Tips how I can detect the malfunctions and where I get the necessary parts would be fine.
regards
bikeone
Start by checking all connectors. They must be tight and clean or filled with dielectric grease. Make sure your hand control switch's are not corroded or have broken wires. Be sure to check connectors between the tank also.
bikeone
Will Check all connections this Weekend.
EHC is on the way to an Electronicexpert for testing with big dog tester.
The front brake switch works how? normal switch or short break?
Srodden
Ok that was my suggestion to send out ECH to wildsteedworxs.com for testing.
You do really need to check every connection you can find no doubt. Chaffing on a wire can be hard to see with dir and oil and hard to reach locations just need to take a little time. I f you pop off the gas tank there's a whole other world of connections there too. Jmo
Rottweiler
Look at you wiring dia. to see which wires to check then I believe the switch shorts to ground.
cdogg556
Hi together,
cable Trouble?
regards
bikeone
My suggestion would be, replace your EHC and harnesses with an ESC from DOC, and then ride the hell outta the thing worry free! :whoop::whoop::whoop::chopper:
bikeone
Got new Iformation from my ehc.
The ehc is tested - seems o.k. - only front light shows a mistake.
But the front light works without any problem( Hi and low beam are o.k.)
Strange - but he will send another one to me for test her in my pit bull.
Would it be a good idea to clean the switches with Isopropanol (98%) and contact spray?
Handlebar connection contact and ehc contacts are clean - like brand new.
bikeone
EHC is okay - brakelight switch and a defect flasher switch seems the mistake.
We will see.
Wait for the switches and my original EHC.
Than I know more.
bikeone
Changed the switch board, right side now is new with new brakeswitch.
Axel built the switchboards new for me. He builds programmable ehc s also.
EHC functions can be changed with horn and flasher switches.
All functions work - If i use the front brake now, the red and Neutral light glows up, when engine not runs and Ignition is off.
Mounted the ehc on vibration killer - maybe a mass problem?
Seems like the right rear flasher burns not so intensive than the other side.
Will give separate Ground (Mass) to the ehc - case.
Since I have and ride my dog, was this the only real defect.
Check 1 of the 4 screws that hold the right hand control board in place, particularly the head of the one closest to were the front brake reed switch is soldered on the pc board, if its touching, it could be shorting out.
Marky-Marc
Also, welches rotes Licht kommt jetzt mit dem Leerlauf Licht an wenn Sie den Bremshebel ziehen?
Sie können mir das alles gerne in Deitsch (Bayrisch) erklären, manchmal ist das umsetzen problematisch.
Leerlauf Schalter und Bremslichter/Rücklichter haben den gleichen Erddraht.
......mir san a bayrische band.....
Familie kommt aus Pöttmes, Nähe Aichach.....
Yep what Mark said...showoff haha
Eumel
Das erklärt endlich einiges, vor allem den teuflischen Nachsatz...
Wäre froh, wenn ich nur einen guten Bruchteil englisch könnte wie du, aber wir in Thüringen mussten damals als "Ostzonen-Deutsche"
halt Russisch lernen - was für ein Graus, ich habe das immer gehasst. Nun ist man halt in dem Alter, wo man sich auch das Auffrischen der Englischkenntnisse erspart.
Halt unsere deutsche Kultur in den Staaten hoch!
viele Grüße von Eumel :cheers:
Marky-Marc
Nachsatz ist halt von einer alten Camel Zigaretten Werbung von den 80er.....hatte damals den Kleber.....neben meinem NENA Schrank Poster....
Habs Abitur aber in Ludwigsburg am Marbach Schiller Gymnasium bestanden.....Schwäbisch kan i au......
Wenn sie was brauchen, bin jederzeit erfüglich....
Komme jedes Jahr zurück in die Schweiz oder nach 'Mingen'....hab noch Familie in München und in Starnberg...aber die meisten wohnen jetzt in der Schweiz.....
Wenn ich nur russisch könnt....dann könnt i mir ne russische Frau 'kaufen'......
Ab und zu denke ich, wenn ich in die s-Bahn in München einsteige, das die deutsche Kultur in den USA heutzutage mehr existiert .....
Prost!
Eumel
Prost!
Für die russischen Frauen brauchst Du kein russisch, sondern nur das nötige Money - aber kein russisches!!
Das mit der deutschen Kultur ist nicht nur in München so...; das kann man so stehen lassen! :spank:
Eumel
DBO.B
Habe die Ehre Marky-Marc und Grüße aus Neuburg an der Donau.. sind ja nur ca 30km bis nach Pöttmes ... Hausstrecke wenn der Dog läuft ;-)
..ich probiers mit Denglisch wie de Lothaa gsacht hat ;)
Servus in die neue Welt
Dietmar
Marky-Marc
Dietmar
Komme diese Jahr wieder....brauchst du teile? Kann sie im Koffer reinschmeissen.....vielleicht ein Gruppen Kauf für Deutschland/Bayern (Free Koffer Versand-hahahaha) .....wenn ich komme, trinken wir hoffentlich 'nen paar Pils oder ein paar Weißbier zusammen......wenn die Zeit es erlaubt...bin gerade daran ein Haus in der Schweiz zu kaufen (versuchen)......
