Heel Toe set up from DLXPRODX
Little-Boo
Looks great Carlos, I am curious why the 2.5" extension plates didn't work? If you end up not using the 2.5" extensions and would be interested in selling them let me know, I been wanting a set of those for a while now.
The new setup is different and will not adapt to the stock controls. The reason being is that the left side forward control is not like the one extended 2.5 inches. It is more like the stock left side control. On the BDM 2.5 extension the right side has a plate the left side is a complete different base that is extended by 2.5 inches, so therefore the new one it will not work. I had to replace the complete left side. I do have a complete set of forward controls (2.5) that are in new like condition. Being the ones that came off my bike. I installed them but did not ride the bike for the last 4 or 5 months so they are new. I will PM you pictures of what I have and details of how we me be able to get you what you are looking for.
Carlos :chopper:
cdogg556
Carlos :chopper:
Thanks Carlos!
Little-Boo
John everything you are looking for is on ebay new or used. I new 2.5 forward control extension kit cost $199.00 and a used left side mount cost anywhere from $35 buck to $79. I am going to send you the link so that maybe take a look at these items.
(1) Complete setup
http://www.ebay.com/itm/BIG-DOG-2-5...ash=item211f2f653b:g:4XsAAOSwd4tUJveU&vxp=mtr
(2) This is what I took off except mine is the extended left side base.
http://www.ebay.com/itm/BIG-DOG-POL...ash=item5693de6492:g:80MAAMXQVT9S3DVB&vxp=mtr
(3) used body
http://www.ebay.com/itm/Big-Dog-Forward-Control-Shifter-Mount-Used-/252730268194?
hash=item3ad7e5da22:g:GcgAAOSw5cNYf7Ry&vxp=mtr
(4) used body
http://www.ebay.com/itm/BDM160-0000...ash=item20d5d1e591:g:cRcAAOxyXTRR9pwm&vxp=mtr
The ones I took off are chrome Tribal shift levers just like the picture and it would cost you more for my setup. I don't want to break up the setup I have. The chrome forward control Levers cost around $329, more or less. Than you have the Chrome Forward control itself that cost about $300, than you have the pegs which is more money. You would be better off to get the complete forward control kit for $199. Unless you can find a plate for the right side and a used left side body then you would be set. I do know that the Tribal levers will give you a little more room like 1 inch because the clock is a little further out (like from 11 O'clock to about 10 O'clock). I do have some polished Tribal levers that I never used or installed that I'll part with for $100 bucks shipped. I was going to make my own Heel Toe shifter with the polished set I have, but never got around to it. That is why I jumped at the opportunity and bought the set I know have.
Hope that helps
Carlos :chopper:
Spikes05
(1) Complete setup
(3) used body
(4) used body
Hope that helps
Carlos :chopper:
So you are going to use the extension plate for the right side? Or are you going to sell your take offs as a complete set? If you are going to sell the take off controls as a complete set how much will you want. I have a physical problem with both my knees and I need to get my legs extended farther out. I haven't been able to ride very much at all for quite a while. So I thought I would see how much you would want for the takeoff setup I don't need the pegs if you want to sell those separate.
Little-Boo
I want to sell it as a complete setup. Thanks for asking.
BTW here is what you need with out any hassles
http://www.ebay.com/itm/BIG-DOG-2-5...ash=item1c7be4a86d:g:4XsAAOSwd4tUJveU&vxp=mtr
Carlos :old2:
Ticey
I read an old thread (started in 2011) where dmcustoms was making a set of 3" & 5.5" forwards then stopped. Do you know if anyone makes a set bigger than these 2.5 inchers? Ill take whatever I can get, n if 2.5 is all I can get so be it, just figured it was worth a shot.
2.5" is the only thing readily available unless someone has some old DM custom stuff the want to sell.
Unfortunately the gentlemen making those is no longer in the business.
TapioK
It is strange no one makes those, it is just a piece of aluminum after all. Yes I know the market is actually nonexistent. But still.
You would think the guy making this heel toe shifter would make these too... Dlxproduct
