Elektronik install
From Curtis .. everything was quite easy but I'm not sure and with no directions I'm reaching out it's Sunday I appreciate the help. The one black and blue has a small black male end . Blue wire looks like a peer wire it doesn't have a plug in it's a splice in ...
Rottweiler
If it was one of axel's the wires should have had small tags on them.
Rottweiler
Not sure if this will help. Tags have stock wire colors and descriptions on them with mine.
That's what I say instructions I don't need them .. I'll say it's a blue power wire not red unless I'm just missing something..
If you need directions for a plug for plug swap out then you should really consider NOT TRYING TO BE A MCHANIC.
Ron, call me as your not going to get the help you need from here.
So what your saying is Ron shouldn't be installing this, he's the one that had the problem?
Depending on when you bought it the later versions have color coded wiring to match the bike.
The early versions we're using one color but I was putting labels on those.
The blue wire I see in your last picture with the plug and turn connector would be for the compression release connection.
Looks like I helped him get an answer to his question:old2:Thanks Kapt, thats all he needed:cheers:
