Where is the ground wire located on a 2007 K9
Guillaume
Put a new ignition in my bike from tractor supply ,But I don't have nothing when I turn my key ,Try to find out my ground wire but Look over and over on my bike and from my negative from the battery I have only three wire one goes to my starter and the other two I think goes to ECM module.
Any help needed from the forum because the weather is nice this weekend in Texas.
Guillaume
It doesn't have a ground to the frame thats why ya can't find it.
You could add one by bolting one onto the rear battery tray bolts that go into the frame but I don't think that's going to solve your problem. The ground on the battery is sufficient to operate the bike correctly. Unless you have an issue with the battery.......
Guillaume
Well my battery is new and full 12.4 so the ground cable is the one that goes to the battery I check that and its clean and tight.
chubs
:agree: The ground going to the starter bolt is the ground
Duh, that makes sense now. I wasn't thinkin about the starter mount bolt. My pit has a ground from the battery straight to the frame, about 7 or 8 inches away from the battery
chubs
Back up a bit. ya put a new key switch from TSC in. Why? what was it doing prior to that? Did it have power then? Anything else you've done ?
Guillaume
Well when I turn my key nothing happen and than my emergy lights came on than I start playing for a while the bike starts , When I came home put the back away ,the next morning the bike did nothing at all ,Then I play for a while and start the bike ,So I Todd the ignition switch was bad so bought today by tractor supply a new one .
FYI!!! I put one of the tractor key switches in Shaine's bike. It lasted about 3 times turning it on and off. Turns out the switch was bad. When I installed it, I had to bend the tabs a little bit to get the nut started, and I mush have broke something inside. recheck your switch.
Guillaume
Well charge my battery is full 13.4 ,Hook it up and check my ignition switch have a little or noting juice on it check it with my little lamp looks like a screw driver.
maybe any suggestion what I can do something els on that bike .
Guillaume
