www.deadonecustoms@yahoo.com"Sounds" Great.... how to I get a hold of Jeff???
UPDATE: Seems after my top end rebuild (cometic gaskets and heads milled .030 for a total drop of .053), the pre-ignition no longer seems to be occuring... or at least I really don't hear any pre-ignition now!Now that's funny!!!
I felt no difference, nor did the bike start easier when I installed mine (TH5012 I believe)... However, I'm hoping to have enough coin one day to have a pro actually "program" it, and I'm hoping that will eliminate my pre-ignition when I crank the throttle in a gear above 2nd...
I did the opposite, 1st was the 585 and that was huge, and you will hear the difference the first time you fire up the bike with that cam in it, I installed the TH at the same time I did the 585 cam. I'm waiting until I come across a Dyno to try the different timing settings to see the results.I recently installed the TH programmable ignition on my 05 117. I have V&H pipes. Before the bike would strain to get to and above 4500 rpm. Now it pulls through 5000 and is smoother at it.. I try to stay above 3k but did not notice much difference between 2500-3500. 585 cam next.
There it is! The absolutely craziest idea on here ever. We all know that TP rocker boxes are way faster than S&S boxes, just like silver paint is way way way faster than red ones. Come on man...........Also you might want to update your rocker boxes to S&S if you haven't already done that ........![]()
What do you mean open up the exhaust and inlet,I fitted the 585 cam and ignition,and getting really bad backfiring.thx Malc.Eric is absolutely correct...but make sure you have opened up your intake and exhaust first.
I also added the Dual runner when I installed the 585 also and it sounded like a machine gun accelerating and decelerating, I also had to rejet the carb and I used S&S's carb guide lines for setting the carb. And I removed the bowl vent screwI did the opposite, 1st was the 585 and that was huge, and you will hear the difference the first time you fire up the bike with that cam in it, I installed the TH at the same time I did the 585 cam. I'm waiting until I come across a Dyno to try the different timing settings to see the results.
I had some additional head and valve work done, added a 630 Woods cam, dual runner and V&H 2-2.Do you have a dyno sheet to see the improvements?585 installed and like the ignition installed a couple weeks ago it provided improvements. Longer flatter torque curve and minor power increase. The smoothness both low, mid and high rpm are not minor. 4500 rpm is now smoother than 3k was before the two upgrades.
Noy yet. But, before the engine would gasp for air and fuel above 4500 it now pulls smoothly through 5500. Thr power gain may be greater than what I feel, but even without power gains the bike rides considerably better than before. Curtis recommends I get the dyno and I woll soon. I need to decide if I am going to stay with the E carb or switch to Mikuni before I dyno it. I don't want the expense of switching manifold and G carb. I am hoping a Mikuni 45 will fit and get the job done. I don't have plans to do heads or 600 cam.Do you have a dyno sheet to see the improvements?
I gotta ask ya, how is your low end with that 630 cam Douggy?I had some additional head and valve work done, added a 630 Woods cam, dual runner and V&H 2-2.
And are you like the other wankers around here that install cams and never rev it past 4,000 rpm?
It just seems like anything over the 585 would be useless unless your gonna build it up to rev the shit outta it, my 585 pulls like hell with no end in sight right to the rev limiter which is supposedly 6,250 rpm!
That explains a lot, when are you going back in to get the rest of it fixedI had some additional head and valve work done, added a 630 Woods cam, dual runner and V&H 2-2.
That's why your replacing head gasketsI gotta ask ya, how is your low end with that 630 cam Douggy?And are you like the other wankers around here that install cams and never rev it past 4,000 rpm?
