yes my ironhorse same wear.I have what seems to be unusual rear tire wear. Heavy ware on the right of center. Of
course there is 11000 miles and the tire is the original from '03
What pressure you run?yes my ironhorse same wear.
Sweet spot for me is 35-36 but I have a pitbull hardtail
36 for me on my mastiff and slammer, both are 300 tiresNo, he has too much air in the left side of the tire....Road crown... typical from what I've seen from other Dogs including mine.
That's what happens when you use the run flatsNo, he has too much air in the left side of the tire....
the air gathers on the left
So between the 315 and 304 that's only 11mm=.433/2=.216, you can file that much off the sidewallUmmm.. sorry guys .. but road crown on the right side of the bike? You are located in the states correct so you do travel on the right side of the road cause road crown wear to be on the left.. just stating the obvious.. anyway, I have the wear more on my right as well.. come to find out the Metzeler is actually close to 315 then 300 and if you align it perfectly it will rub the belt. So my next set will be factory avon's that are actually about 304mm.. n e ways.. good luck.. take ur axle covers off the rear and measure the distance from front to back on each side..
You go ahead and file all you want, lol.. not what I'm gunna be doing on my baby.. maybe if I had a spyder or a cheap ass harley... lmao!!! JkjkSo between the 315 and 304 that's only 11mm=.433/2=.216, you can file that much off the sidewall![]()
Its much better than jacking the axle and riding down the road true doggy styleYou go ahead and file all you want, lol.. not what I'm gunna be doing on my baby.. maybe if I had a spyder or a cheap ass harley... lmao!!! Jkjk![]()
Or changing the Avon tire again cause it split in half, been there done that with 1500 miles on the Avon, wouldn't want that happening to your baby now would ya, I'm glad the Spyder don't take Avons
Depends on Sue's mood, been riding two up quite a bit since she broke her throttle wrist early in the summer. Tire seems to be holding up just fine, got about 4500 miles on it now.Are both you guys riding solo, I know you are Dent. I'm afraid to run that low with 2 up and the low sidewall, saw this on my last tire and it was only 3 yrs old
Its much better than jacking the axle and riding down the road true doggy style![]()
Gots a point there..
