I agree single tank is the way to go..it will make the bike look longer.Story on the pitbull is it is eventually going to be my project bike 04' pitbull. The rear compression release threads stripped and my compression release backed out. I had a machine shop do the repair but the motor is out of the bike. You can see it in the back of my BBC on the image. I am considering converting it to a single gas tank instead of the split tank design.View attachment 37975View attachment 37976
I think you should stick with the one on the wall... a lot less trouble...View attachment 37980 When you put in the BDL also go in with a lock up clutch!!!
I am a bit OCD when it comes to clutter and organization. That really helps when taking things apart and getting them back together. Right now my garage is a mess with one bike torn apart and my sons car being worked on.I agree single tank is the way to go..it will make the bike look longer.
I also like the looks of a well done blacked out bikes but it's always a toss up caise black and chrome is timeless
Where do you put all your shit that garage is so empty compared to mine!!!!
You call that a mess?? You have seen Eric's garage haven't you...I am a bit OCD when it comes to clutter and organization. That really helps when taking things apart and getting them back together. Right now my garage is a mess with one bike torn apart and my sons car being worked on.
Lock up clutches are no trouble and they grab! The more power applied the harder they grab. Yes they do take a little getting use to, but an experianced rider will be good to go after 4-5 takeoffs. For those who have never tried one. The lock up clutch does not slip. It grabs! With centrifical force through ball bearings the harder you roll the throttle the harder they dig in. 99.99999% of all drag bikes run them. When I had my closed primary I would romp on my bike quite hard and the clutch would slip.so when I put on my open primary I went with the lock up and it don't slip. Like I said, takes a little getting use to and you have to ride it a little different. But yes very much worth it!!!I think you should stick with the one on the wall... a lot less trouble...
I was referring to the bike he had hanging on the wallLock up clutches are no trouble and they grab! The more power applied the harder they grab. Yes they do take a little getting use to, but an experianced rider will be good to go after 4-5 takeoffs. For those who have never tried one. The lock up clutch does not slip. It grabs! With centrifical force through ball bearings the harder you roll the throttle the harder they dig in. 99.99999% of all drag bikes run them. When I had my closed primary I would romp on my bike quite hard and the clutch would slip.so when I put on my open primary I went with the lock up and it don't slip. Like I said, takes a little getting use to and you have to ride it a little different. But yes very much worth it!!!
I use the front break from rolling backwards!I was referring to the bike he had hanging on the wall
The clutch sounds fine if you want to fast take offs and such but what about stopping on a hill? I use the clutch to keep from rolling back when I let off the brake.
So fill me in on this lock up clutch a little more please, I'm still a little ignorant. So you do not use a clutch lever and to shift you just back off on the throttle and shift and the only time you're not moving is at Idle?Lock up clutches are no trouble and they grab! The more power applied the harder they grab. Yes they do take a little getting use to, but an experianced rider will be good to go after 4-5 takeoffs. For those who have never tried one. The lock up clutch does not slip. It grabs! With centrifical force through ball bearings the harder you roll the throttle the harder they dig in. 99.99999% of all drag bikes run them. When I had my closed primary I would romp on my bike quite hard and the clutch would slip.so when I put on my open primary I went with the lock up and it don't slip. Like I said, takes a little getting use to and you have to ride it a little different. But yes very much worth it!!!
No, it works same as a normal clutch with a clutch handle. With either wet clutch or a dry clutch they can slip. With a lock up there is no slippage. You have ball bearings using centrifical force to compress the disk.So fill me in on this lock up clutch a little more please, I'm still a little ignorant. So you do not use a clutch lever and to shift you just back off on the throttle and shift and the only time you're not moving is at Idle?
Yeah just be sure not to cover the transmission shaft splines in red lock tight!!! Like he shows in the video.
Yes HD uses the same input shaft as Baker transmission's
I hate to disagree with you but I bought a BDL open for a Harley and the clutch shaft was too small. I had to have it machined to fit the baker.
Mine fit no problem! On my offset I added a 1.25" spacer to the motor side. That is for a 2003 BIgdog chopper 107" motor with a baker 6 speed transmission. I also ordered mine for a 1996-2005 soft tail and told BDL I was using a Baker transmission.I hate to disagree with you but I bought a BDL open for a Harley and the clutch shaft was too small. I had to have it machined to fit the baker.
Ok thanks for the vids makes it all very clear. Don't know if I'll be getting one anytime soon but will make a good option if I happen to tear my clutch or chain drive up. They do look very cool.
That's why it fit. they sent you the Baker clutch.View attachment 38053
Mine fit no problem! On my offset I added a 1.25" spacer to the motor side. That is for a 2003 BIgdog chopper 107" motor with a baker 6 speed transmission. I also ordered mine for a 1996-2005 soft tail and told BDL I was using a Baker transmission. View attachment 38052
Nice! But $2k? I think I got mine on ebay for $1,200. Looks great though.View attachment 38055 I put this 3"BDL on mine for 2k.
Best investment I made for the Dog.
