To adjust the carb...
Some educational reading by S&S
S&S carb adjustments
S&S Shorty Carburetor Adjustments
S&S Carb Manual
http://www.sscycle.com/modules/instruction/uploads/51-1012.pdf
For my 2 cents...
with the bike warm...
(in=clockwise/out=counter)
if your idle is low... turn it up a bit...
now spin in the accel pump screw till it seats.
now spin in your fuel/air mix screw till the motor sounds like it wants to die
now spin it back out counting 1/4 turns. Do it slowly to give the motor/carb time to adjust. Do this till the motor sound like it wants to die on this end. Now you have counted those turns and you have say 2.5 turns. Spin it back in 1.25 turns. Or middle to almost dead on each end.
Now adjust your idle to 1,000 rpms on the tach.
Now spin it out 1.5 turns
Now with a few quick stabs at the throttle see if the rpms come up fast like you would think or if it kinda hesitates then takes off. If it does hesitate then spin the accel pump out another 1/4 turn and repeat till you get what sounds good.
If that don't fix the sneeze... you can spin out the accel pump a bit more... but anything over 2.5 turns MAY mean you need a larger intermiediate jet. This is a common debate.
Then re-adjust your idle to about 1,000 RPMs. Too low and it may die. Too high and it will clunk into first gear.
Now on the plugs... to test run the bike and see if the jets are good. This can also be done before you ever screw with your jets.
Check or replace plugs.
run the bike but keep the RPMS below 2500... then don't let it idle and kill the motor, check the plugs. That is to help check the int jet.
Then take it out and run it hard... keep the RPMs up and romp on it... then on a striaght patch of road with the RPMs up high (over 3k, or even higher) kill the motor with the OFF switch. Pull the plugs and check. that is to test the main jet.
The idea here is that your int jet runs from idle to about 2750. Then the main kicks in from there out. That's why we say your run mainly on your int jet. main is only for romps.
Use this
GUIDE to read your spark plugs. The basic idea is white is lean, black is rich. What you are aiming for is a nice cinnamon color to the grounding tip.
To talk jetting...
One of the most common problems is...if you are expierencing a cough at highway speed 75mph +/- RPMs at about 2750... cough thru the carb... go up on int. jet.
To jet the carb... click these links for sniplets out of the how to
(post #2, 7-8)
http://www.bigdogbiker.com/forums/how/13-how-remove-your-carb.html#post58
http://www.bigdogbiker.com/forums/how/13-how-remove-your-carb.html#post63
Of coarse once you change the jets you will need to re-adjust the carb again.
