Nomad2day
Longhair Redneck Geek
Ohmster or Jason,
Got a issue that started today with the speedometer. Went on a 60 mile trip. On the way back, the speedometer just pegged out at 120 mph while riding. When I stopped it would be at 90 and never return to zero. Turned if off and it stayed at 90 and when it swept it pegged out again. When I got home I checked the battery for tightness and wiggled the wiring. I pulled the speed senor and it has a large flat spot on it as though it has been shaved off. The Odometer is working too.
I removed the speedometer from the bracket and moved the wire and it went to zero. When I power the bike up, it pegs out on the reset button but on the zero side of it now. Turn the key on and it may sweep up to 25mph but then again pegs out on the reset button on the zero side.
The engine light and oil light glow dimly and have for a week or so. Started after I washed it one day. I checked the neutrual switch to be sure it was not wet grounding out. Help Please. I held the left turn signal and powered up. All the leds came on for 3 seconds and all went out. Just the orange power stays on the the green flashes, controller on.
The speedometer has stayed fogged up for months now.
The tachometer, back lights works fine as well as the turn signals, the speedometer needle just stays pegged out.The Odometer is working fine also.
Thanks for any help.
Neil in Tenn
Project # GEB70253
Neil in Tenn
Project # GEB70253
