Need help
Vin Cent
anyone know where I can get a replacement right hand circuit board and wire bike won't start take it aport mess with it it work and I can get bike to start put it all back together and it don't work tried lots of things must need new ones thanks
Matheny 514
Just to make sure, did you ensure that the lock tab on the connector in the right hand control was not broken or cracked? While assembling the control, it is quite easy to shift/move it in a way that the connector becomes unplugged if the lock tab is broken or cracked so that nothing on the right hand control works. Maybe not fully disconnected but still something to check.
Make sure it's fully connected and seated and clean.
Marky-Marc
If the brake magnet sensor wire or the main wire gets wrapped around the handlebar/grip when putting it back together it will pull the plug out, just like @Matheny 514 said.....it's a tight fit and has to be done carefully....it's tough I know because of the throttle cables....I do have a video somewhere of it though....cheers...
TapioK
I hate those connectors and too tight fits. Pain in the ass specially if you try to put them together alone... i think those expensive controls with bad quality chrome, outrageously expensive boards sold only by pair and those rubber condoms (not sold alone) are about reason enough to to oldskool....
Your hanging with Bill to much
